Rust Repair Question
Old Sep 1, 2018 | 06:26 PM
nickmkk's Avatar
Default Rust Repair Question
I'm fixing the rust on my 4th gen Trans Am and have a question. There are a couple spots on the floors where it's rusted through so I cut out those spots to weld in a patch panel but the metal underneath is also rusty. I'm wondering what I should do here, should I just clean up what I can and weld in the patch or should I remove the whole floor pan and fix all the rusty metal underneath as well? What would you guys do in this situation? Thanks for any advise.
Old Sep 5, 2018 | 07:54 PM
Jfwyatt1's Avatar
ospho or Eastwood rust encapsulate both work pretty good for enclosed panels. Ospho can be sprayed with a undercoat wand and turns rust into iron oxide the Eastwood stuff just seals it and prevents it from getting worse.
Old Sep 6, 2018 | 09:35 PM
nickmkk's Avatar
Thanks, I ended up opening it up some more then cleaning it up and painting it with por15. I think most of the por15 burned up when I welded in the patch though, oh well.
