Windshield Header Rust. Can it be Fixed
So I was getting the windshield replaced on my 98 Trans Am and the technician brought me out to the service bay to show me rust damage on the passanger side windshield header. I don't take the T-tops out often so this was a surprise to me. Has anybody else seen this and had it repaired? My car is a low milage car but for the last couple of years has lived outside.
He got a crack in his windshield and got a mobile glass installer to come by his work. The installer found bubbles along the edge of the windshield under one of the t-tops and said he couldn't continue. My brother called me a bit upset because his car is a 9.5/10 car and had no reason to have any rust anywhere. I told him to bring the car down to my dad's garage after work and we would figure something out. The glass installer guy was cool and left my brother his personal number and said he would come by the garage after his normal work hours. We got the car stripped down for the glass guy to come by and remove the windshield, which he did amazingly quick. The rust was caused by the corner of the windshield being loose. The factory windshield urethane glue/sealant bond was broken. Luckily it is a pretty heavy gauge metal structure around the windshield and t-tops because it would have rusted through a thin gauge metal. I'm no professional body man but I hold my own pretty well. I wire wheeled the rusted area clean, put on some locktite rust neutralizer, filled the divots left by the rust with fiberglass resin, and then 2k primed the area that evening. The next evening we picked up a pint of single stage MAE and some hardener and I sprayed the t-top jamb with an old touch up gun. The paint dried overnight and the glass guy came by and put in the new windshield.
All in all it wasn't a huge deal, and as an added bonus my brothers t-top jamb is slicker than oem.
My T/A is only a good detail away from 9/10. It's only got 37,XXX miles on it and is all original. I dropped it off yesterday at a shop recommend to me by several people I know. I'm waiting for a written estimate from them but the windshield has to be removed first. I'm hoping it isn't too bad damage and cost wise. Maybe all it really needs is what you were able to do with your brother's car.
This is how I got my large rear window into my 1967 C10. I cut it out of one in the bone yard and went though all 3 batteries we had that day. Did that one 5 year ago with the same flange trick. What a difference in the thickness of sheet metal though between 67 and then a 1999. It's Huge!
Hey. I was building my car and there was no rust anywhere. When they took my windshield out, they found rust all across the front where the windshield meets the roof. I halfway freaked out. I took it to a guy that had done some work on my Squarebody and he fixed it for $300. Zoom in on the pictures and you can see how good it turned out. He sliced out the rust and welded it a new piece and painted it up.
