FAST lettering delete/factory texture?
Old Jun 21, 2019 | 04:02 PM
2001CamaroGuy's Avatar
Default FAST lettering delete/factory texture?
I'm picking up a used cathedral port FAST 92 and I'd like to remove the lettering (personal preference). I intend to paint it flat black and would like to keep the factory-ish texture so it looks like a factory manifold. Obviously to remove the lettering, I have to sand off the letters. Sanding the letters will leave me with smooth spots unless I wet sand the upper entire manifold. If I sand the entire upper manifold, it won't have the factory-ish texture.
So the real question I guess is how do I mimic the factory texture in the areas that end up smooth (due to sanding the letters off)?
Old Jun 21, 2019 | 11:14 PM
LLLosingit's Avatar
Your best bet would be to sand it all and retexture the whole thing so it matches, There are some paints that will give you a textured finish or you could use one the products available to add texture before painting. http://www.semproducts.com/product/t...oating/coating
Old Jun 22, 2019 | 08:19 AM
micbegz28's Avatar
VHT Has a wrinkle paint that works awesome on metals, but im not sure if it works on plastic.
Heres an overflow tank i just did. If you throw the part in the oven(or a heat gun would work i guess) the wrinkles become more pronounced.
Old Jun 22, 2019 | 10:29 AM
jlcustomz's Avatar
Something I kinda played with before on other plastics was heating the surface in a small area, then quickly pressing something with a similar reverse pattern against it, such as maybe 80 grit sandpaper or a piece of copper with a hammered texture.
But on the common side of plastic bumper repair, textured spray such as the SEM mentioned or from Polyvance , then a finish coating is used. A good epoxy, such as SPI black (is glossy)would have great bond & be a finish coat for such a part. Also with SPI expoxy, if you let it sit in sealed container mixed a day or 2 & shoot with low air pressure, you will get a texture coating. See post 5 in link, this wasn't intended, but could be replicated with thickening mixture & low spray pressure.
http://www.spiuserforum.com/index.ph...-of-coat.6434/
