Detroit Speed fender protectors
I'm wondering if
A. has anyone used these and how did they like them
B. has anyone built/made their own? Looks pretty straightforward
C. are there any competitors out there? $115 seems a little extreme for what it is
My flanges are mangled all to hell and the fenders sit too far out and have a sad looking door gap. I can straighten them but I'd like to keep them from getting damaged again in the future
Twa Motorsports on YouTube installed them on his TA. Look up his video.
Alright. Well I'm not gonna choke down 120 bucks for what it is.
So if I ever end up making a set, I'll post some drawings/pictures so someone else can copy.
Cheers fellas
Cheers fellas
Just as a matter of clarification, those plastic, honeycomb pads to which I refer do not serve the same role as the Detroit Speed part. They protect the fender and pinch weld only if you use them as a lifting point as opposed to the fender or pinch weld. They do not in anyway support the fender or pinch weld. You can still mangle that pinch weld if you lift outboard of the pads.
As far as not using the OEM pads as a lifting point, I never realized there was any controversy or concern about using them. I thought that is their intended function. I never lift or support the front by those pads without having a flat, solid block of wood directly contacting them, though. I am not arguing. What would be the concern?
