Undercoating
Old Dec 5, 2019 | 09:07 PM
2000BLKBIRD's Avatar
Default Undercoating
Have a 94 anniversary edition trans am. Does anyone know if these were undercoated from factory. Mine has black undercoating just under the door sills from front to back
Old Dec 6, 2019 | 03:05 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
A complete undercoating was not applied to any of these cars on the assembly line, only the partial coating that you see under the rocker panels and inside the rear wheel wells.
Many dealers offered an undercoating service (at extra cost) when these cars were new, so you may have seen some relatively new, low mileage examples with complete coating for this reason - but it was not applied on the assembly line.
Old Dec 13, 2019 | 10:17 AM
Enigma540's Avatar
do you have any idea how one would go about removing that 4-5 inch wide strip of undercoating along the rocker panel, without damaging any paint that may be under it? That's some knarly looking stuff, and I was wanting to strip it and redo it with something a little cleaner and less "prehistoric tar pit" looking. Maybe something like lizard skin, or raptor truck bedliner. Both have a finer, more consistent and modern look to them.
Old Dec 13, 2019 | 02:53 PM
RPM WS6's Avatar
On the Pontiacs, the area of factory undercoating also included a little strip on the forward portion of the wheel well/quarter panel lip (this lip is narrower on Camaros, therefore was not sprayed with undercoating at the factory). I thought it would look cleaner to remove this extra little strip of undercoating on my Trans Am, so I used some Brake & Parts cleaner to strip it off. It actually came off very easy, with no damage to the paint underneath. The only caveat is that I did this back when the car was brand new, so it may have come off much easier then than it would now. ~20 years later, it's likely going to be harder to strip.
The aftermarket undercoating is usually much easier to remove, I've stripped it off of cars decades after it was applied using various medium-grade chemicals (such as kerosene, mineral spirits, etc.), but the factory stuff seems a bit more bonded/firm.
Old Dec 13, 2019 | 06:16 PM
Enigma540's Avatar
I've stripped what I assume to be aftermarket type undercoating from my 2wd k5 with a scraper, a torch, and some brake clean. Tedious, but not difficult. Once it gets hot and gooey it scrapes off fairly easy. I just didn't want to use the torch under the formula and start messing up whatever is under the coating. Thanks for the tip on the brake clean, I'll try that will some gentle persuasion from a plastic scraper over this winter and see how it goes.
Old Dec 14, 2019 | 01:51 PM
Rick Dorion's Avatar
I used an electric heat gun and plastic scraper with good results when I removed all the underneath undercoating on my 68 camaro. I wiped it down with mineral spirits and the bottom looked like a new car.
Old Jan 6, 2020 | 07:29 AM
indyjps's Avatar
Undercoating is random chemical composition, could be tar or plastic based.
kerosene, diesel, mineral spirits, acetone, will cut the tar based. GM uses a tar based spray on truck frames, could be the same stuff.
test kerosene and mineral sprits on an area of paint, make sure it wont eat the paint, use a heat gun on the undercoating and plastic scraper, egen the plastic razor blades.
Heat, scrape, solvent that doesnt harm the paint.
I like all the UPOL products, gravitex and lizard skin. Been using them for years. Have a 12 year old lizard skin bedliner in my truck, has not faded or broken down.
