new paint not smooth?
I disagree that a glass surface can't be achieved without wetsanding. IF the painter knows what he is doing and adjusts his gun and technique for the environment and conditions, ie. temp, humidity, etc. and technique being gun speed, air adjustment, overlap and reducer in the clear, then YES a great surface can be achieved.
It sounds as though we have a lot of folks in this forum giving advice who have never even lifted a paint gun
OH yea, by the way, if you put wax on that new paint job already then you messed up and better get if off right away. Your painter should have told you yet. Even though the paint may be dry and hard it takes a minimum of 30-60 days for the paint to fully cure and all the solvents to be released. Otherwise the wax will hold in the solvents and prevent the proper venting. This will lead to problems down the road such as delamination, lifting, etc.
Bryan
parbreak
We are not all painting Madana's car here. Just get out there and try. If you have enough clear or paint in single stage you can wet sand and buff to a mirror finish. No shame in that game.
Sean Penn probably gave that car to Hugo Chavez anyway.
