Conveting LT1 TA
Old Jan 8, 2007 | 01:46 PM
Flow Wizard's Avatar
Default Conveting LT1 TA
What does it take to convert LT1 front end to a LS1 Type Front on Firebird?
Anyone have the part numbers?
Old Jan 8, 2007 | 04:42 PM
NothingTrivial's Avatar
I remember a couple threads on here about that, try searching for them, I dont have the link right away, but if no one else has I'll post them when I get off work and get home. IMO, its a waste of money, I almost did it at one point and time. I thought better of it though...save up for an LS1.
Old Jan 8, 2007 | 06:50 PM
RUNINHOT's Avatar
Just buy a newer one, its honestly worth it. If you really want to though, heres a few parts you need.
1.RH fender
2.LH fender
3. Metel brackets to attach fenders to car if there aftermarket 8 total gm#???
4.Hood
5.Bumper rebar (if TA, so foglights will have a place to mount)
6.Bumper absorber(firebird and TA are different from one another)
7.Bumper cover
8.RH headlight assembly(get it used or it gets expensive)
9.LH headlight assembly
10. RH side marker lens
11. LH side marker lens
12. RH DRL lens
13. LH DRL lens
14. Fiberglass bumper cover mount
15.Foglights
16. Head light wire harness (depending on the year of your car)
Old Jan 8, 2007 | 07:14 PM
This is going into a drag car and the main reason is the lack of 4" coweled hood that are available to the firebirds.... yes i need it for clearance not for looks.....
Old Jan 8, 2007 | 08:24 PM
RUNINHOT's Avatar
Well then check out VHN http://www.vfnfiberglass.com/site.htm
They are a sponser and cary 4 inch hoods that fit LT1 firebirds. They also offer front clips in the ls style. There products are great constuction and very lightweight compared to others.
Old Jan 8, 2007 | 10:31 PM
redramair98's Avatar
1.RH fender
2.LH fender
4.Hood
7.Bumper cover
12. RH DRL lens
13. LH DRL lens
15.Foglights
sounds right i just did one of my cars a few months back, and u can hard wire the headlights without rewireing or changing harness
Old Jan 9, 2007 | 03:15 PM
DMH Fabrication's Avatar
1.RH fender
2.LH fender
4.Hood
7.Bumper cover
12. RH DRL lens
13. LH DRL lens
15.Foglights
That looks like most of it. You don't need the reinforcement bar though. You can still attach the fog lights with self taping screws and save some money...also if it matters, the bumper cover is abs plastic and not fiberglass. You may want to try calling Contemporary Corvette. They generally sell an entire front clip for the purpose of swaping onto a LT1 car.
Old Jan 9, 2007 | 09:43 PM
RUNINHOT's Avatar
The part where the top of the bumper cover mounts is a fiberglass peice that ties into the headlights and core support.
http://www.tennesseeauto.com/
Here is a sponser that that sells complete kits with ever nut and bolt for about 2k.
Old Jan 9, 2007 | 10:38 PM
MyWs62FaST4u's Avatar
<---converted... also try "tacreations" I think its a dot.com
Old Jan 9, 2007 | 10:39 PM
Ebay FTW!!!!!!!!
Old Jan 25, 2007 | 06:38 PM
azvforce's Avatar
Just look for a roller and get all the parts you need off of it.
I bought an '01 NBM T/A with no engine, trans, or wheels for $900. I sold off the leather interior, rear axle, Ttops, etc and recouped my $900 in no time.
Old Jan 25, 2007 | 08:45 PM
95formulalt1's Avatar
i did it!!! loved doing it!!!! car looks sick and sounds better then a ls1 IMO!!!!!!!!!!!
