Trouble spraying clear..?
Bryan
1. Type of clear being sprayed. By this I mean the clear itself, the speed of the hardener and reducer used with it. They have to match the temperature of the booth.
2. The size of the nozzle in the gun, and the setup of the gun. By this I mean the "fan" of the gun and the ""fluid" of the gun. The fluid is the screw on the back that stops your trigger and limits the amount of fluid coming from the needle. Having this too far in can cause a dry spray.
3. The compressor volume. Can the compressor keep up with the airflow of the gun?
4. Painter. Picture the needle of the gun as a pancil or pen, and keep it perpendicular to the surface you're painting. Keep a moderate overplap... like 40-50 % of your last pass and you should get no dry spray.... if all the other conditions are right.
