How Front Frame Rail Look?
that straight up cost you 10k
someone made out with that
and I'm not just pullin that outta my ***... I used to buy wrecks from Copart and have em repaired professionally.
~Brian
I hope I can get this thing back together, nothing structural seems tooooo messed up, just alot of body work and ldriver side lights, i'm gonna need to find a junkyard with a parts car for sure, hopefully black... and i'm not even worried about the hood right now, just wanna get it together enough to hit the road again.
you got *** raped if that was $4k...unless there was frame damage...
bumper=$500 MAX on ebay
fender=$150
fixing the hood=$500 MAX I would think...
painting everything and matching it right...i fixed this...
for a little over $1800. paint was only $350 since I knew a guy, parts direct from GM Dealership(entire front clip, 2 fenders, bumper, absorber, full headlight assembly since it was cracked in half basically, underside pieces)and I did all my labor...
btw RrCoX22 I PMed you...
If your refering to my bumper fix, I really hope your right! lol
obviously the rails have to be bent back or cut, both side fender frames need to be bent straight, then welding of side panels, bumber bracket and front crossbrace
Other than that, now that I have most of the crap off nothing else seems to outta wack, minor stuff like the washer fluid tank and hood release bracket are damaged but they are removed and in the parts pile. All it really seems is the rail end is jacked. The flanges on the end are so bent up I don't really know how to get the last bolt out for the impact bar!
2 inches is nothing my trans am front came over almost 9 inches and it goes down the road str8 as any other car, doesnt wobble or pull either way and drives and rides awesome.
I'm just hoping this frame **** can be handled fairly low priced and without too much hassle, Ithink it's gonna need the end chopped about 8 inchs back and a new piece installed, it's just mangled to hell, but the length of the rail seems to be in alignment, it just took the blow dead on the end.
I'm gonna hope to just find another wrecked bird with a untouched front clip and get the rest of the parts and panels cheap.
