TA Headlamps
Old May 6, 2007 | 11:49 AM
SamD_Ind's Avatar
Default TA Headlamps
I was wondering if there is a wat to stop the headlight from flipping up/down then you arm/disarm the alarm system using the key fob?
thanks
Sam
Old May 6, 2007 | 12:20 PM
2001somws.6's Avatar
Is there a sound coming from the lights when you use the keyfob? If so your gear in the motor is striped and you will have to fix it.
Old May 6, 2007 | 02:18 PM
Drew's TA's Avatar
sorry dont mean to hijack, but the same thing started to happen to mine 2 days ago, making the grinding sound too. How do I fix this, is there a guide somewhere?
Old May 6, 2007 | 02:54 PM
06TDI's Avatar
The gear is stripped inside, do a search, you will find lots on it. Everything from replacement of the motor, to putting brass gears in, to turning the stripped gear around to catch the other side. Only 1 side of the gear is stripped.
