Damaged SS Spoiler
Is this fixable? I planned on getting it painted for my birthday on the 14th so do I fix it or get an aftermarket spoiler?
What would be the best way to fix this so that I can use the original screw? I'd think it would be a pretty similar method to the fix needed for the first post... ? 5 bucks max!!!
As for fixing the door (above), same method here would work, or you could glue/glass in a small piece of sheet metal to the area, drill a small hole in the metal, and not worry as much about it pulling out again.
The thread on it resembles a wood screw more than metal. It's not a fine pitch screw for the part that goes in to the SMC.
It'll take you. . . .30 minutes (and let it dry for a few hours). Like someone else said, put the stud into the jb weld while it's wet and let it dry there. Problem solved!
