Paint experts--take a look at this........
Some loser must've airbrushed over a scratch and now the little scratch looks 100 times worse because now there is a big area that you can tell has been painted and it looks like crap.
If I had the door clear coated, would that blend in the edges of where it was air brushed?
It looks like ****
I waxed it today after I took the pics and it's much less noticeable, but I'm sure that after a couple of days it'll reappear. I tried buffing it too but that didn't work.
I was thinking that if the whole panel was cleared that it'd hide the foggy edges of that spot kind of like the wax did, but I don't know for sure.....just guessing.
Re-clearing it will help, but to make it perfect it will need to be sanded smooth and new base blanded over top of it before re-clearing.
Guys, ive been doing professinal paint work for years on ferraris, porsches, and pebble beach winners. When painting a car IN A REPAIR SHOP that say has a dent in the front of the fender, you repair the front of the fender, prime it, sand with 400-600, and then sand the rest of the fender with 1000+, and it will match perfect if the guy mixing the paint looked at his variances, and did a few test sprays
Now, when talking about blending paint, it looks to me as the painter there didnt use enough blending addiative, he didnt rub it out the right way ( you have to know how to rub out blends the right way to not see where you sprayed) and he didnt go to the rear edge of the door which would have made it easier to conceal. basically, he just put a huge splotch in the middle of a door, thats the wrong way but it can be saved.
Killa, your pics are really blury, first off, did you pay for this or buy the car that way? Im assuming you got the car that way or you would have taken it back to the shop, if you didnt, do that and tell them they suck, and to never paint again. Having the job have dirt in it further makes it a shittty job. What have you tried to make it look better besides wax? Any rubbing compound? Heres what you do first, get some regular rubbing compound, and rub a small spot on where he painted, if it comes off body color, just stop right there and save for a repaint, because you will just make it worse at this point. If it doesnt and rub side to side making sure you get the painted, and unpainted areas, try to put some speed into the rub to heat up the clear and make it disappear, and check how it looks frequently. If you can make it better, get some imperial hand glaze, and rub the whole door with it, mind you these two products arent like wax, you dont put them on and wait to get hard, you rub into the paint and thats it. the hand glaze will make the blend marks and scratches further go away. and then you can seal it up with some wax.
Now if that doesnt work and you have to get it painted heres how you can save yourself some money. Get 1000 grit sand paper, and a 3m flexable rubber squeegie, a bucket of warm water with some dish soap in it, and some tape. Tape off the edges of the door because its to easy for a newbie to burn through them. Then clean the door off first with the dish soap to strip wax, junk, dirt, so on. then sand the door, side to side long ways, untill its dulled up, again, dont go crazy, you just need enough to have uniform smooth finish, then take the door handle, mirror, trim off, and drop it off to get sprayed, by the looks of it, you dont need color on the whole door since it seems the repair is actually ontop of the door clear, so that will save you money/ time from blending the fender and quarter if you dont mind having a shiner door.
Hope this helps , good luck
