clear coat question
Old Aug 26, 2007 | 02:25 PM
01T/A88IROC-Z's Avatar
Default clear coat question
You guys know any way to bring back the clear coat shine after some 2000 grit wet sanding? please desprite for help.
Old Aug 26, 2007 | 03:38 PM
900hpSS's Avatar
buff wax polish. it will shine up you just need to spend some time polishing
Old Aug 26, 2007 | 03:39 PM
Camaroholic's Avatar
Wool pad on a rotary buffer with some compound. Brings it right back.
Old Aug 26, 2007 | 05:08 PM
Pheonix's Avatar
Black Foam pad and 5936 3M buffing compound and the lowest RPM between 1 and 2 should be fine.
Old Aug 26, 2007 | 08:11 PM
I just used Mequira's Smooth Surface clay kit. Best 20 bucks I ever spent. Fixed the clear coat and also used it to remove the coated line from around where the side molding used to be. Thanks for you guys help.
