Finally did the passenger HUMP delete!!!!
Old 01-22-2011, 11:39 PM
  #121
1MeanGreenZ28's Avatar
Very cool mod!
Old 01-23-2011, 12:08 AM
  #122
PUNISHER TA's Avatar
That is awesome. Id really like to do that sometime.
Itd be worth it, just so I didnt have to hear people whine or make any comment about it.
Old 01-23-2011, 04:29 AM
  #123
The Dragon's Avatar
Thumbs up
Out of curiosity, would a UMI Tubular K-member need modifying to do this hump delete?
Nice work BTW
Old 01-23-2011, 05:27 AM
  #124
UNDER PRESSURE MOD
The Alchemist's Avatar
Originally Posted by 9t8z28
How high does that lift the chassis?
The bottom of the lift ramps goes to 6', so add 3" for the ramp height, and then to the bottom of the chassis.
I'll put it this way, my buddy Tommy welded in my subframe connectors and he's at least 6'3" and he had no problem being under there.
In this pic, the TA is one lock from the top, so add another 6".
Old 01-23-2011, 10:37 AM
  #125
White.Lightning's Avatar
Nice work BTW
The k-member does not need to be modified at all. If I ever change to a different cross member, that will need to be modified but it shouldn't be a big deal.
Thanks for the compliments
Old 01-23-2011, 12:44 PM
  #126
guy7bmwm83's Avatar
Those lifts are very cool. I saw one advertised in a car magazine over 10 years ago and have always wanted one.
Old 01-23-2011, 04:35 PM
  #127
2001-CamaroSS-LS1's Avatar
im like a hop skip and a jump away from you....does buddy wanna do another one?....thought....do you have to be catless?
Old 01-23-2011, 06:05 PM
  #128
I can ask. He did this when he was unemployed for a month or two so he had time during the day to do it. I don't think catted or non-catted would make a difference as long as its an aftermarket ypipe. Stock exhaust manifolds and stock ypipe might pose an issue.
Old 01-23-2011, 08:02 PM
  #129
FreakishSpeed's Avatar
I am usually a fan of HUMPING ( lol ) but this is a great job getting no HUMP.
(these titles and sentences make it really hard not to laugh my *** off as I say them LOL)
Old 01-24-2011, 06:30 PM
  #130
blacksleeperLS's Avatar
I hate the bump...Had no idea you had to mod the cross member.
Old 01-29-2011, 03:26 PM
  #131
I was over Brien's house today and took two pictures of the underside. It's basically what I described above. The dark marks you see is where the exhaust heated up some of the seam sealer. Eventually, the whole underside of my car will be semi gloss black and/or undercoating.
The above pic shows how close the floor is to the ypipe. Even with PatG's car shown below, and the heat shield, you can see how far away the ypipe is from his floor board. Note the placement of the cross member in both cases. Mine is almost flush with the ypipe.
Old 01-29-2011, 09:13 PM
  #132
The Mighty Texan's Avatar
Looks great I hate the passenger hump.
Old 01-30-2011, 07:47 PM
  #133
9t8z28's Avatar
I wish you would have waited until I could have met up with you two to see it or gotten some pics that were farther away so I could see the depth of things. Did you take anymore pics?
Old 01-30-2011, 08:33 PM
  #134
If you look at the second picture you can see how close the floor is to my ypipe now. Go look under your car and you'll see that the floor was lowered like two inches. Once you start cutting things out, it can only really go back together one way when using the frame rail. I guess you'll just have to figure it out.
Good luck!
Old 01-30-2011, 08:35 PM
  #135
FastRidesOnly's Avatar
i still need to do this. would it decrease the value of my z28?
Old 01-31-2011, 08:05 AM
  #136
UNDER PRESSURE MOD
Sorry, I've got a 2 year old and a 4 year old and a wife who has her own company so time and scheduling are minute by minute sometimes.
It was a decision at 8am on Saturday morning while I had to run into work and Andy made it to my house by 10am. We were done by noon and he was on his way.
This spring when the weather is better and I have more time, you can stop on over.
Old 01-31-2011, 01:48 PM
  #137
LS1rob00's Avatar
Looks great, I didn't even know people did this mod, but it really does look so much better than stock!
Old 07-17-2023, 01:08 AM
  #138
Peter Windle's Avatar
Default Yay!
Hello and g'day from down under...! I was super excited to see this article, since I have a right hand drive converted car and I was thinking of getting someone to do this for me.
Just one thing: I would like to know ho much room this leaves for a cat underneath the floor? I have a high flow cat on mine, so there should be enough space to drop the hump, but by how much, I'm not sure...?
Old 07-17-2023, 06:37 AM
  #139
It would be flat, like the driver side. Use that as a reference.
Old 07-17-2023, 06:38 AM
  #140
Good point. I'll have to take a look under there and see where the cat sits.
Quick Reply: Finally did the passenger HUMP delete!!!!
