POR-15 Chassis Coat
POR-15 Chassis Coat
I have used regular por-15 for my 9" rear, it worked very well and im pleased with that. I am currently grinding and preping my underbody for POR-15.
I saw chassis coat as a top coat to por-15, Has anyone used this?
How much por-15 would it take to cover the underside from rear end up to the back of the engine bay? Quart?
Thanks!
Thanks!
Restricted User
haven't used the top coat stuff but I did POR15 the **** out of my frame where some rust got to. You should be just fine with a half gallon. That stuff really goes a long way.
STIR CONTENTS GENTLY AND THOROUGHLY before painting.
Do not shake.
Refrigerate unused portion of POR-15 for longer shelf life.
Apply in thin coats, 1 to 2 mil thickness. Minimum 2 coats.
It recommended more in marine applications...i think under body of a car would apply. maybe 4 is over kill....
Topcoat when first coat is dry but with slight finger-drag remaining, usually 4-5 hours.
Do not shake.
