Got a new bumper about to paint it.
One of my other bumpers I did like this I took it down to the urethane tho. It turned out smooth as glass.
Wet sand 360
adhesion promoter
k36
block
seal
base
clear
Preparation of New Primed Plastic Parts
Though new primed parts do not need the application of an adhesion promoter, they do need to be cleaned using the three-step method (hot soapy water, isopropyl alcohol, and wax-and-grease remover). The primer should be scuffed with a gray abrasive pad and sanding paste, water-rinsed, and then re-cleaned with wax-and-grease remover. At this point the anti-static agent should be applied. If the part has no bare plastic showing through the primer, adhesion promoter does not need to be applied. The application of color coat and clearcoat then proceeds the same as on other parts.
