Best way to remove over spray
Old Mar 6, 2008 | 04:52 PM
Derek_02's Avatar
Default Best way to remove over spray
I had a fender painted a while back on the jack off that painted it got over spray on the hood. What would be the best way to get it off. Should i wet sand and buff or will a claybar do it? Thanks for the help.
Old Mar 6, 2008 | 06:17 PM
torquejunky's Avatar
Yes I'd start with a clay bar (a real one not the liquid garbage) then a cleaning compound (if necessary) followed by polish and sealer wax. Do you have a buffer/polisher? That would make things much easier....
Old Mar 6, 2008 | 07:32 PM
dennsterTA's Avatar
agree 100%. A clay bar kit works wonders. Then some good wax.
Old Mar 6, 2008 | 09:18 PM
Derek_02's Avatar
Ya i have a polisher/buffer. What do you recommended as a good compound to use and a good wax. I'm just not sure the difference between a cleaner wax and regular wax.
Old Mar 6, 2008 | 10:59 PM
I like just about anything that 3M makes, it's a little more expensive than some stuff but IMO its the best. If you go around and look in body shops about 90% use 3M. A cleaner wax is basically a combo of polish and wax, but I would still seal it. Or if you need to, use a polish to cut a little more, then wax and hit it with a hand glaze.
Old Mar 7, 2008 | 02:08 PM
turbozcamaro's Avatar
try claybar first, does wonders
Old Mar 7, 2008 | 03:24 PM
Derek_02's Avatar
cool thanks guys. One more question, what clay bar kit do you recommend? Mothers or Meguires?
Old Mar 7, 2008 | 06:38 PM
I don't have any experience with either of those, but as long as they are the bars and not liquid they should be ok. Maybe someone else has experience with one of those two and will chime in.
Old Mar 7, 2008 | 06:55 PM
Fast_94_Z's Avatar
i just use my rotary buffer. you could also use soem compound by hand. if its on a window then i use steel wool.
Old Mar 8, 2008 | 10:59 AM
haven't used either but I would guess both would work well. I would probley use meguires, but thats just me, its your choice.
Old Mar 8, 2008 | 12:01 PM
Fast_94_Z's Avatar
i like 3m compounds
By Brett Foote | 2026-06-04 05:00:17
