How to fix hood alignment?
Old Apr 7, 2008 | 06:53 PM
Kalgorn's Avatar
Default How to fix hood alignment?
The previous owner had an SS hood installed (or installed it himself) but the alignment is ****. It has always bothered me but I never looked into fixing it. How can I modify the alignment? I'm not sure I see a way to fix it because it almost seems like the hood doesn't match the curve of the fender. Here's some pictures:
Old Apr 7, 2008 | 08:51 PM
mycamaroSS's Avatar
AHHH seems like all our cars end up having unaligned hoods. But for me i would just take it to a shop and im sure im gonna get quoted saying "dude it's so easy to fix" haha. Just get an estimate to see how much it would be and if it's reasonable than get it professionally fixed
Old Apr 7, 2008 | 10:03 PM
conde'strans's Avatar
It's not always the hood that needs realigning might also be the fenders that are messed up or been replaced and not installed very well. I'm not content with my hood's alignment either but I already gave up on it(F**K it)!
Old Apr 7, 2008 | 10:06 PM
mycamaroSS's Avatar
you make a good point but if you look at his fender it's aligned with the light and also aligned with the door.
Old Apr 7, 2008 | 11:12 PM
SparkyJJO's Avatar
How much you wanna bet it isn't OEM SS hood so the curve of it isn't quite right? Or maybe the fender isn't OEM..
Old Apr 8, 2008 | 12:24 AM
mycamaroSS's Avatar
^im leading more towards the hood man, which sucks *****. Dude just bring it into a shop and have them look at it because i know when my hood wasnt aligned with my bumper it made me go crazy...
Old Apr 8, 2008 | 05:12 AM
Kalgorn's Avatar
Sounds good. I thought about taking it to a shop to get an estimate but I wanted to see if I might be able to do it myself.
No clue if it is an OEM hood or not but it does have the vent opening underneath the hood for the scoop. Not sure if aftermarkets have them or not.
Old Apr 8, 2008 | 08:11 AM
9000th01ss's Avatar
The fenders are adjustable.
Old Apr 8, 2008 | 11:08 AM
Dave 96TA's Avatar
While we're on the subject, anyone know the p/n for the hood bump stops?
Old Apr 8, 2008 | 11:53 AM
mycamaroSS's Avatar
uh no, oem ss hoods arent functional, so that is an aftermarket hood
Old Apr 8, 2008 | 11:57 AM
9000th01ss's Avatar
Yea they are. There are two channels built into the under side of the hood that connect the hood grille to three slots that line up to the air box when it's shut.
Not saying it increases performance or not but if you blow air into the scoop it will come out under the air box.
Old Apr 8, 2008 | 09:04 PM
Wsteun's Avatar
lol yeah they are.
Old Apr 8, 2008 | 09:30 PM
mycamaroSS's Avatar
o **** lol just saw those and could never find the holes, well i didnt really look
Old Apr 8, 2008 | 10:01 PM
O-townLS1's Avatar
One of my friend's hoods did the same thing. The reason his did that was bacause he leaned on it not paying attention. Maybe your hood is bowed somewhere. Try letting the hood all the way up and looking at the side of the hood that runs along the fender. Check and see if it has any bends in it that would make it lower in that one spot.
Old Apr 11, 2008 | 09:44 AM
VINCE TA's Avatar
Wink How To Properly Aling A New Hood
TRY TO DO EVERYTHING U CAN MAN!!!! LOOSE FENDERS,FRONT BUMPER, PULL, REMOVE,PUT SOME SCREWS IN THE FRONT BUMPER BLA BLA BLA................................ PLAY WITH IT AND HERE'S A LINK! GOOD LUCK BRO! http://armorysound.com/forumsadv/showthread.php?t=27
Old Apr 11, 2008 | 03:29 PM
Kalgorn's Avatar
Well I stopped at a body shop today to get a quick estimate and he told me that he would feel bad having me spend money trying to get it fixed because he doesn't think it can be. It just doesn't look like it could ever match the fender lines and I agree.
Did any aftermarket SS hoods ever come with the "functional" underside? Perhaps it's just a **** poor aftermarket knock off. Gives me an excuse to swap the hood out for something else if I ever do a full repaint.
Old Jul 17, 2008 | 02:26 PM
98blackbirdta's Avatar
the owner could have made it functional and thiers a couple people on ebay who sell functional fiberglass hoods wich i almost feel into sounds apealing but they really never fit right u can tell if its aftermarket or not u have to check out a oem ss and lift up his hood and feel it up its barley there but u can feel it hope this helps
Old Jul 24, 2008 | 03:18 PM
INMY01TA's Avatar
Aligning the hood is easy. Just loosen the hinges. Dremel out the holes in em if you need more movement out of em.
Old Jul 24, 2008 | 03:33 PM
Brian2006's Avatar
I'm willing to bet its the fender. You can tell the center of the fender is bowed upwards a bit. It'd be a lot more tough to find a hood that was built that improperly than it is to have a misaligned fender.
