Leaky T-tops!
Old May 18, 2008 | 02:03 PM
Mong00z's Avatar
Angry Leaky T-tops!
I'm sure most of you guys with T-tops have had problems at some point with them leaking. I have rather new upholstry and would like to fix the problem soon! They never leak when I'm driving, only when it rains hard when the car is just sitting, and the one time this winter it snowed I found a puddle in the back floorboard. . . .Not very happy.
Is there any easy fix to the problem? I know you can buy replacement seals, but I don't know if I could put them on myself or if they will work any better than the origionals.
Appreciate any help,
-Zach
Old May 18, 2008 | 02:07 PM
z28_YOU_HO's Avatar
Old May 18, 2008 | 03:50 PM
SparkyJJO's Avatar
Which t top is leaking?
You can adjust the holes where they attach, that might help. Also, check your seals for any pinches. My passenger one had gotten stuffed under the plastic end cap a bit and was creating a spot for water to get in. I pulled it out and made sure to not let it get back under there when I put the cap back on and it has been fine ever since. I even washed my car with the high pressure washer at a car wash and I had no leaks from that.
Old May 18, 2008 | 05:01 PM
Mong00z's Avatar
Its not a certian one. Sometimes its the passenger, sometimes the drivers side. Ill have to look, so maybe one is pinched or not in place. By the holes, do you mean the holes where they lock in?
Old May 18, 2008 | 07:10 PM
SparkyJJO's Avatar
Yes. You need to take the plastic covers off (2 screws) to get to them.
Old May 18, 2008 | 08:01 PM
Tall Guy's Avatar
I did a write-up awhile back. Maybe it'll help some-
https://ls1tech.com/forums/general-maintenance-repairs/588223-leaky-t-top-fix.html
Old May 18, 2008 | 09:04 PM
Mong00z's Avatar
Thanks for the write up tall guy. Pics are kinda blury up close, but I think I see what you are saying.
Old May 19, 2008 | 06:52 AM
tektrans's Avatar
I suggest getting sub frame connecters installed. Our cars flex alot and the subrames will stiffen it up and not let the t tops dance around so much up there.
I have a '98 and have had subframes since day 1 and the t tops have never leaked.
Now I have a 10pt cage and many wheel standing launches and still no leak.
Old Jun 3, 2008 | 03:06 PM
xRelapse13's Avatar
you can also check to make sure ur t tops are adjusted so that they are a tight fit, i used this link and it helped out pretty well
http://www.dayton-fbody.com/DFBAbb/v...249a328169e51a
Old Sep 10, 2008 | 02:39 PM
5301113's Avatar
saving this
Old Sep 11, 2008 | 06:43 PM
Shockwave179's Avatar
Good info here.
Old Sep 11, 2008 | 07:01 PM
Zeke34's Avatar
Originally Posted by 5301113
saving this
+1... Been fighting the leaky passenger side T-Top issue since last year and really want to put a stop to it.
