- Chevrolet Camaro 2010-Present: How to Replace Side Mirror
Step by step instructions for do-it-yourself repairs.
Browse all: Chevrolet Camaro or Pontiac Firebird Exterior Guides
Both of my side view mirror brackets are broken.
Both are broken in the same area as in the picture below. I tried to find replacement brackets but not luck. Many places told me I have to buy the whole mirror assembly which I don't need. Can this be welded? I'm going to try the JB Weld stuff to see if this works. My only concern is that this might be a temporary fix. Has anybody else dealt with this situation or am I the only one? If you have any other ideas or advice please let me know. Thanks in Advance
Still on there after a few years.Just be sure to:
-clean it very well
-make any part that you're 'welding' rough so that it has an area to bite in to - 80 grit or lower sand paper. It won't stick as well if the surface is smooth.
-don't be afraid to slather it on
-make sure you let it set for at least 24 hours. don't rush it, don't think after 4 hours "it must be solid now". Wait 24 hours.
-don't be afraid to embed some metal reinforcement inside the JB Weld itself. This can be strips of metal, etc. Anything across the break that can give it more strength. Run the metal at a 90 degree angle to the break and squish it in to the JB Weld.
I woulda sent it to ya for free. But i'd say goto a junkyard and find some. I mean it's not like it's a mechanical part or something.=\
. This time I am going to try the JB Weld. Last edited by 1CAMWNDR; Jun 13, 2008 at 01:42 PM.
as far as getting the part, you could call RMS. they have a connection with delphi and can get parts which are normally only available in kits/whole parts
search emergency brake lever boots
they made them available for me when I called them; it took about two weeks
Thanks Camaroholic
Oh I also used industrial gauge staples straightened as my vise grip pinch point ( so that the vise grip won't get stuck the the JB stuff) and as a reinforcement to the JB.
