Lowest Trans Am in the World - Radical Thinkers Only!!
#42
i think that this is a great idea. i've always thought about what a chopped top t/a would look like but i'm not that good with photoshop. also if you do make this you could end up selling a chop top conversion kit or something along those lines because im pretty sure that once people see the final product they might want to go towards the same route. i know i would love to see the end result and probably if you do end up selling it i would be very interested in buying something like that. mainly i would like it because it pisses me off how my car is as low from the ground as my dad's 1990 ferrari testarossa but it is so much shorter and i like the look but could never achieve it.
#44
Definately not a good idea for a tall guy. Heck i'm only 6' 1" and I feel cramped with the head room I have stock. Good luck on the build tho and if thats what your into then go for it.
#47
I like those short exotic cars as well and that was the look I was going for. If you get the chance, try and measure your dads car from the lowest part to the highest. I'm just curious how it would compare.
#48
It's a zero cost mod that is equivalent to a shortened shock.
#49
Assuming I moved the A/C to the rear, do you guys think it would be worth it to set the engine back? Maybe 9-12". The only real issue I have would be leg room. Would I have to move the pedal assembly, steering wheel and seat back an equal amount?
Another small issue. I'm looking for a flooded or parted out firebird donor car right now so I can strip it down and see all the internal parts. Eventually, I would transfer all my drivetrain, interior and body parts over to this donor car. It will be a Frankenstien in a sense. Do you think I would have any issues getting it insured or registered?
I would be registering the donor car, right, as they go by the VIN number on the dash? Does this mean I need to avoid donor cars with no title or a salvage title? I guess a junkyard car would be out of the question, then. Any thoughts on this from Texas members?
#50
tuck the wheels up bro, just don't get ghey and throw 26's on it. are you chopping the top and leaving the t tops? i think the t top, chopped, would look sick as hell. personally, if you're gonna get low, i'd say do a truck. but a super low f body would be different.
#51
UNDER PRESSURE MOD
I'll be posting a mod that will allow the front tires to tuck up and extra 1.25". The stroke will be the same meaning the tires will droop 1.25" less. It doesn't effect the ride height, but it will give you a smoother ride as you won't be on the bumpstops as much. OR, you could lower your car another inch and have it ride the same as it does now.
#52
You can't really chop the top and use the stock t-tops as they will be too short front to rear. I did consider a targa top, but I don't know about that.
Do you have any idea how to get a truck down to 35" tall? It ain't happening.
Black Trans Ams for life, Bro.
#53
Due to the fact I'm replacing the suspension and tubbing the rear, it would be very easy to alter the wheelbase. The only thing difficult would be moving the wheel openings. The back would be just metal work, but the fronts may be too difficult. Does anyone make fiberglass TA front fenders?
Anyway, here it is with the front wheels moved forward.
![](http://img.photobucket.com/albums/v335/JasonWW/99%20black%20TA%20new%20rims/IMG_2971x5.jpg)
Here it is with both front and rear wheels moved forward.
![](http://img.photobucket.com/albums/v335/JasonWW/99%20black%20TA%20new%20rims/IMG_2971x6.jpg)
Do any of these ideas strike a nerve?
#56
I swear everytime i look at it I think Batmobile. As a matter of fact it looks way better than the Batmobile. I think it looks pretty damn cool. Is custom glass (front or rear) expensive? Good luck with the project and just make sure its safe.
#57
#60
good luck if you plan on jumping in. once you build a rolling chassis with a full frame (which really is simple stuff especially if you use a 4-link or IRS) and build a firewall and inner fenderwalls etc. Your main issue and most time consumeing part is the body work. shapeing that roof and getting the glass cut and everything is gonn take alot alot alot of work. raising the wheel wells is the easy part...
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
