Dynotune Air/Fuel Ratio Lean Shut-Down Switch
Category: Engine - Electrical
Price: $0
Location (State): IL
Item Condition: Used
DynoTune Air/Fuel Lean shut-down switch is the original and only A/F switch available. This tiny stand alone device(you need nothing else to make it work other than your factory o2 sensor or wideband controller) is a Microprocessor controlled Air/Fuel ratio Lean shut-down switch that will shut off the nitrous system if it goes lean during a Nitrous run and best of all, It works with your existing OEM oxygen sensor! (0-1v oxygen sensors)(or 0-5v wideband controllers.
