Complete 12" Subwoofer system with Sub, Amp, Enclosure, and Capacitor
Category: Audio/Video/Electronics
Price: $300
Location (State): FL
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Thanks
James
Subwoofer
Model: MAGMA-12
• 1500 Watts Max
• FS=28Hz
• Qms = 9.9846
• Qes = 0.4043
• Qts = 0.3886
• VAS = 5.71Ft3
• Xmax = 0.5"
• 85dB 1W/1M
• Revc = 6.78
• Levc = 6.3mH @ (1 kHz)
• 3" Dual Voice coil(2x3.2 ohms)
• MSRP: $402.75
Amplifier
Model KAC-9102D
Kenwood built the KAC-9102D amplifier from the ground up to power your subs with authority. Its rugged cast-aluminum chassis houses an efficient Class D mono power section that'll punch out up to 1700 watts without putting a strain on your car's electrical system.
A built-in low-pass filter adjusts amplifier output so you'll get the best sound possible from your subwoofer/box combo, while the subsonic filter eliminates inaudible, ultra-low bass that can hamper performance. Speaker- and preamp-level inputs, plus preamp outputs, provide flexibility in system design and hookup.
The top-mounted controls allow you to tweak the sound easily, and convenient front-side connections make setup a snap.
Details:
• mono subwoofer amplifier
• 1700 Watts Peak Power Output
• 500 watts RMS x 1 at 4 ohms (850 watts x 1 at 2 ohms)
• variable low-pass filter (50-200 Hz at 24 dB per octave)
• variable bass boost (0-18 dB at 40 Hz )
• subsonic filter (15/25 Hz, 18 dB/octave )
• top-mounted controls
• Class D design
• CEA-2006 compliant
• speaker- and preamp-level inputs
• preamp outputs
• fuse rating: 30A x 2
• MSRP: $299.99
Subwoofer Enclosure
Type 3 Enclosures – Large Vented
Type 3 Enclosures are perfect for those that are willing to sacrifice a little extra cargo room to get additional output! Type 3 Enclosures have an in-car tuning frequency of 34 Hz, so they’re ideal for those of you with a wide range of musical tastes.
To get the maximum output, Type 3 Enclosures use a large slot vent. When compared to a smaller round vent, these huge slot vents have a considerable output advantage!
All Type 3 Enclosures include the following in addition to the enclosure itself:
• Qxs Mounting Ring(s)
• MSRP: $179.99
Capacitor
Capacitors are the ideal way to add a little extra power to your system by storing an electrical charge temporarily. These single farad capacitors from Raptor are perfect for mid-level systems up to about 1000 watts. A true and accurate 1 farad cap, along with the 24k gold plated brass terminals are perfect for transferring the needed power. With a size that is small enough for any installation, this capacitor from Raptor is a great solution for your vehicle!
• 1.0 Farad Capacitor from Raptor
• True 1.0 Farad Capacitor for systems up to 2000 watts
• Built in digital display
• Working voltage 20/24 volt surge
• E.S.R. less than 0.002 Ohm
• 24K Hard gold plated brass terminals
• Uses ring terminals to connect to the needed power cable
• Includes mounting hardware for a secure installation
• MSRP: $99.99
