Fast 90 - HSW - FJO - Fuel System
Category: Engine - Power Adders
Price: $1200
Location (State): KY
Item Condition: Used
LS Engine?: Non-LS Part
Fast 90MM Intake Manifold
Speed Inc Billet Fuel Rails
- Includes two sets of mounting brackets. One set was supplied by Speed Inc.. Those will work with stock height LS1 injectors, with LS1/LS6 and Fast intake manifolds. The other set I fabricated for using LS2 injectors with this Fast intake. (LS2 injectors are shorter than LS1)
- All Custom Stainless Braided Lines, and AN Fittings.
Harris Speed Works Nitrous Kit
- 90MM Plate System
- HSW Purge Kit
- Custom Solenoid Brackets
- Insulated wiring with quick disconnect plugs at back of manifold
- 4AN Long Feed Line (Should be 16 feet.. I have bottle mounted in trunk)
- Jetting up to 150HP
- 10LB Metallic Blue NOS Bottle with Bottle Pressure Gauge
FJO Progressive Mini Nitrous Controller- Updated for use with Windows 2000, XP, Vista and Seven
- Full Programable.. Works as window switch, electronic wide open throttle switch, first gear lockout, as well as time, and RPM based progressive ramps. Can control two stages independently. Really kickass controller.
Located in Lexington, Kentucky. Willing to ship at buyer's expense.
![](http://i4.photobucket.com/albums/y149/BillyBob750/Nitrous1.jpg)
![](http://i4.photobucket.com/albums/y149/BillyBob750/Nitrous2.jpg)
![](http://i4.photobucket.com/albums/y149/BillyBob750/Nitrous3.jpg)
![](http://i4.photobucket.com/albums/y149/BillyBob750/Nitrous4.jpg)
![](http://i4.photobucket.com/albums/y149/BillyBob750/FJOController.jpg)
