FS: 220 amp Alternator w/ASP Overdrive Pulley & Custom Relocation Kit
Category: Engine - Electrical
Price: $300
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): TN
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
I am changing my pulley setup completely so I'm selling my current high amp alternator/relocation kit.
The alternator is a high output 220 amp from Power Bastards. It uses the same Delphi case with better internals so it fits the same as the stock unit. The ASP overdrive pulley also gives it 15% more power efficiency so it keeps a steady stream of power for all your accessories. This is even more important if you already have an underdrive crank pulley which doesn't turn your accessories as fast. This alternator was only on my car for about 500 miles and did a great job powering my stereo with 2 1,000 watt amps, my nitrous kit and all its accessories, and all other accessories on the car at the same time with no surging issues.
![](http://i79.photobucket.com/albums/j155/cbwasson/501543f3.jpg)
![](http://i79.photobucket.com/albums/j155/cbwasson/25c4c240.jpg)
![](http://i79.photobucket.com/albums/j155/cbwasson/08ce6e7b.jpg)
The back vent horn has been trimmed to add clearance for the relocation.
![](http://i79.photobucket.com/albums/j155/cbwasson/bfc3682a.jpg)
$230 Shipped
This custom alternator relocation kit was made by TurboZ28408. It moves the tensioner down to where the alternator bracket originally was and allows you to use the stock style alternator. These are quality made, CNC machined brackets that are built tough.
![](http://i138.photobucket.com/albums/q268/SpoolinPhil/alt%20relo%20bracket/DSC01566.jpg)
![](http://i138.photobucket.com/albums/q268/SpoolinPhil/alt%20relo%20bracket/DSC01579.jpg)
![](http://i138.photobucket.com/albums/q268/SpoolinPhil/alt%20relo%20bracket/DSC01575.jpg)
![](http://i138.photobucket.com/albums/q268/SpoolinPhil/alt%20relo%20bracket/DSC01571.jpg)
![](http://i138.photobucket.com/albums/q268/SpoolinPhil/alt%20relo%20bracket/DSC01568.jpg)
$85 Shipped
The alternator retails for $290 from Power Bastards, the overdrive pulley retails for around $20 from ASP, and the custom relocation kit cost me around $120. I'll sell it all together as a set (including the proper belt) for $300 shipped.
*You may need to measure for a custom belt if you have a UD crank since the one I have was for a stock size crank.
