EFI 400 eng, turbos, Tial WGs/BOV, intakes, efi
Category: Engine - Intake/Fuel
Price: $1
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird, Front wheel drive vehicles
Location (State): AL
Item Condition: Used
Engine: Small Block
LS Engine?: Non-LS Part
If you know of someone looking for a system capable of 1900 HP on alcohol, maybe a little less on gas I have all of the major parts to put it together. This is very low use system that I put down 1076 rwhp (approx 1350 motor HP) with only 12 lbs of boost. Everything here I have used personally other than the intake with no injectors below.
complete turn key 500 HP EFI engine sbc 400. bowtie block, AFR heads, roller cam, all forged. With controller ignition..everything. All accessories too. Plug in car and go. ($6,500)
18 degree sb chevy EFI intake with 172 lb/hr injectors and 2000 CFM throttle body ($1200)
Fast fuel injection system with wide band ($900)
sb chevy EFI intake with out injectors ($250)
(very little use) 2 76 mm turbos
2 44mm Tial waste gates
2 Tial blow off valves
Filters
About 1900 HP capable on Methanol, less on gas.
(Will sell as single turbo systems at $1500 per system-1 turbo, 1 WG, 1 BOV, 1 Filter)
Like new Waterman 7 gal per/min Mechanical Fuel pump with cam drive kit for sbc. 2500 HP capable on methanol, 3500 + HP on gas.
New Weldon 2047 Fuel pressure regulator. This is a typical Pro Street fuel system ($850 Pump/reg/adaptor/fittings)
