Racetronix in line 255 fuel pump
Category: Audio/Video/Electronics
Price: $75
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO
Location (State): AL
Item Condition: Brand New
LS Engine?: Non-LS Part
Saturday bump. This is the fuel pump only. It will work with the Nitrous outlet hot wire kit. If you splice in a weather pack connector to the pump. The hot wire kit has a connector for a booster pump. This is a universal pump and will work with the intank pump. All that is required to install is a ground wire to body and the hot wire to 12v switched source or to the fuel pump fuse and splice the pump into the fuel line ( if you don't do or have the HOt wire kit). There is a spot on drivers side where the fuel lines come out of the tank, it can be spiced in there and mounted there as well. I just bought the pump to install for higher nitrous pulls but my clutch let go and clutches and flywheels are not cheap. So I have to sell it and don't want to becuase I will have to turn around and buy another one just like it after I resolve my clutch issue. ATTENTION: you do not need a hot wire kit to intall this pump.
