MSD 2351 Programmable Fuel Pump Voltage Booster
Category: Engine - Intake/Fuel
Price: $200
Part Fits: 93-02 Chevrolet Camaro
Location (State): MI
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
NOTE: The Fuel Pump Booster cannot be used on fuel systems without a return line (pulse-modulated pumps) or (mechanical returnless).
The MSD Programmable Fuel Pump Booster is the best and easy way to maintain the proper fuel pressure on your car after adding a power adder such as a turbo or supercharger. The Booster ensures that the engine receives the fuel it needs to make up for the increase in air being pumped into the intake manifold.
The Fuel Pump Booster will increase the voltage to the factory fuel pump in proportion to manifold boost pressure in order to maintain the proper fuel delivery. The amount of increase is adjustable from a range of an additional 1.5 -22 volts up to 30 psi which can all be set and adjusted from your PC with MSD's easy to use Windows based software.
Features & Benefits:
Effectively maintains fuel pressure and volume while increasing boost
Deliver an additional 1.5 - 22 volts to the fuel pump
Accurately program the boost and voltage output ratio via your PC
Easy USB connection and Windows based software
Use with factory pumps or with a secondary booster pump
