Accel DFI Gen 7 Fuel injection EFI + MSD HVC + Dual sync distributor REDUCED
Category: Engine - Electrical
Price: $1500
Location (State): NC
Item Condition: Used
Engine: Small Block, Big Block
LS Engine?: Non-LS Part
•Accel DFI Gen VII programable EFI system
•CalMap GEN VII v 4.0.1 software
•CalMap programing cable
•Both PRO key dongle (USB) that unlocks all software features and Sportsman key (Serial) for limited features
•Accel Dual Sync distributor that allows for true sequential fuel injection
•MSD HVC ignition box and high vibration coil.
•Wiring harness
•Custom mounting panel that holds the computer, ign box, relays, and fuses.
This panel is designed to bolt in a 67-68 Camaro glovebox opening for easy access, but could be modified to fit pretty much anywhere.
This is a very powerful system with many features such as boost control, launch control, staged nitrous control, tuneable sequential injection, and much more. It can be used in conjunction with most wide band O2 sensor systems for closed loop operation at all loads and speeds. It worked excellent. I was very pleased with all the tuneability, features, and performance. The only reason I am selling it is I have switched to an LS based engine that came with it's own stand alone EFI computer and harness.
This system was used on a 67 Camaro with a built small block and a Weiand Stealth Ram port injected intake and Vortec style heads. The complete intake, injectors, throttle body, etc is available seperate. In fact the entire engine is available if interested and is pictured for reference.
$1600
Joe (828)381-0391
![](https://blufiles.storage.live.com/y1p1m0xmL7QH3-YEMJMpafoR8hNRqlQSTOYXKSPdJiArHHWJxTq14v7QsljklFZ1gibZamPoBK6Ngs/IM002038%20(Medium).jpg?psid=1)
