317 Heads - tanked, valve job, Comp Cams 918 springs, titanium retainers & more!
Category: Engine - Intake/Fuel
Price: $600
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): PA
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
*Tank and clean
*Valve job
*Polished combustion chambers
*Comp Cams 918 springs
*Comp Cams titanium retainers
I bought these and installed them on my car a couple years ago. I only started it a few times and never ran the car. I got a different set of heads to raise my compression ratio. These cars will lower your CR and would be ideal for turbo or supercharged engines, especially if you're running any sort of aftermarket cam and/or a stock bottom end.
This is a really good deal - add up the work & parts and you'll see:
*Good low-mile 317 heads - $200
*Valve job - $150
*Polishing combustion chambers - $100
*Comp Cams 918 springs - $180
*Comp Cams titanium retainers - $240
If you want, I have a set of stock rockers, rocker mounting bars, and rocker bolts. I'll throw them in at no charge.
I also have a set of GM graphite gaskets that I can throw in for and additional amount. They are LS1 gaskets but will work, especially if you are running a 5.7L bore.
SOLD! I will double box them. Sale is contingent on me successfully removing them from my engine. I should be able to take them off next week. Here's a pic from right before I installed them.
![](http://www.buyrcars.com/IMG_4177smallest.jpg)
![](http://www.buyrcars.com/IMG_4176smallest.jpg)
