Aeromotive Belt drive fuel pump and mount For LS1
Category: Engine - Intake/Fuel
Price: $500
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): WA
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Aeromotive 17140 Fuel Pump Kit (Fuel Pump, Mounting Bracket, Pulley)
Aeromotive 14 tooth drive pulley
Gates Drive Belt
Custom Drive Mandrel (Custom fitted to install on a Power Bond Harmonic Balancer)
Custom Made Mounting Bracket to mount pump on Any LS1 Engine (Iron & Aluminum Blocks)
From Aeromotive's Website:
Zero amperage draw, less weight, and more flow!
The Aeromotive Billet Belt Drive Fuel Pump was designed to solve fuel delivery problems in high horsepower, forced-induction EFI applications, as well as the now popular, carbureted applications on gas or methanol.
• Proven performance, powering some of the world’s fastest EFI vehicles.
• Supports up to 3600 HP gas, 1800 HP methanol.
• Compact size facilitates easy mounting.
• Billet aluminum CNC-machined body, not “cast”.
• ORB-10 inlet and outlet ports.
• For EFI applications use regulator P/N 13113.
• Carbureted gasoline applications require regulator P/N 13202 or P/N 13212.
• Alcohol applications require Double Adjustable Regulator P/N 13209 or 13214.
• Bracket and Cog Pulley sold separately. (see Accessories)
• Available as a kit (P/N 17140) includes: Pump, Bracket and Pump Pulley.
Aeromotive’s Universal Fuel Systems are designed to provide the do-it-yourselfer with ALL the hardware and components necessary to properly install a “full-on” Aeromotive fuel system. If you’re building a street/strip car or one strictly for racing, you can select one of the systems available for carbureted or fuel injected engines. Suitable for installation in any chassis, these systems provide a wide range of performance, from 250 to 2000 HP.
Bottom line, if you’re tired of fuel delivery problems, Aeromotive has the fuel system solution you’ve been looking for. Designed to provide outstanding performance through matched component selection and correct installation, these systems offer the results only years of engineering experience can provide, while eliminating confusion, wasted time and unnecessary expense.
