2003.5+ Vette HOB A1000 Fuel System & MagnaFuel 4303 ProTuner 750 In-Line Fuel Pump
Category: Accessories
Price: $3050
Location (State): TX
Item Condition: Brand New
LS Engine?: Fits LS Engine
- A1000 supports 1000hp for Forced Induction, 1300hp N/A
What's included:
- In-Tank Fuel Pump with Inlet Filter
- Pressure Tube and Top Plate
- Fuel Level Bracket for Factory Fuel Level Sensor
- Passenger side Regulator Restrictor Plug
- Jet Siphon Hose with Quick Disconnect (no cutting required)
- Fuel Pump Speed Controller
- Fuel Pressure Regulator
- Inline Fuel Check Valve
- Pre-cut Fuel Lines with all fittings attached
- Fittings to connect fuel lines to the In-Tank Pump
![](http://i256.photobucket.com/albums/hh171/adam205348/IMG_2726.jpg)
![](http://i256.photobucket.com/albums/hh171/adam205348/IMG_2727.jpg)
![](http://i256.photobucket.com/albums/hh171/adam205348/IMG_2728.jpg)
![](http://i256.photobucket.com/albums/hh171/adam205348/IMG_2729.jpg)
![](http://i256.photobucket.com/albums/hh171/adam205348/IMG_2730.jpg)
![](http://i256.photobucket.com/albums/hh171/adam205348/IMG_2731.jpg)
![](http://i256.photobucket.com/albums/hh171/adam205348/IMG_2741.jpg)
![](http://i256.photobucket.com/albums/hh171/adam205348/IMG_2742.jpg)
![](http://i256.photobucket.com/albums/hh171/adam205348/IMG_2743.jpg)
![](http://i256.photobucket.com/albums/hh171/adam205348/IMG_2744.jpg)
![](http://i256.photobucket.com/albums/hh171/adam205348/IMG_2745.jpg)
![](http://i256.photobucket.com/albums/hh171/adam205348/IMG_2746.jpg)
![](http://i256.photobucket.com/albums/hh171/adam205348/IMG_2747.jpg)
If you want even more power you will need more fuel to run it safely so I also have a external fuel pump setup that has already been plumbed into this fuel tank and is capable of supporting 2,000HP N/A or 1600hp FI but in combination with the A1000 intank setup capable of SO much more.
MagnaFuel MP-4303 ProTuner 750 Series In-Line Fuel Pump
ProTuner Series
Engine Hp: up to 2,000+
Once-piece design is more compact and light weight.
Ideal for street muscle cars
Quiet operation
Self-priming
Continuous duty
No pump shaft seals, no leaks
Pump body CNC machined aircraft aluminum
High-torque custom motor with very low current draw. Never requires stepdown
More efficient than other motors
Double support bearings
Rebuildable to as-new condition
Compact design fits in smaller spaces
Smaller than competitive pumps, lower current draw, more powerful
Hard anodized, long lasting finish
Mounting bracket included
Vertical or horizontal mount
Polymer wear plates for smooth, quieter operation
Fuel Filter
Y-Block
SS Lines with fittings
This entire Fuel System was on one of Dallas Performance's most powerful Corvettes to date without any problems.
![](http://i256.photobucket.com/albums/hh171/adam205348/IMG_2732.jpg)
![](http://i256.photobucket.com/albums/hh171/adam205348/IMG_2733.jpg)
![](http://i256.photobucket.com/albums/hh171/adam205348/IMG_2734.jpg)
![](http://i256.photobucket.com/albums/hh171/adam205348/IMG_2735.jpg)
![](http://i256.photobucket.com/albums/hh171/adam205348/IMG_2736.jpg)
![](http://i256.photobucket.com/albums/hh171/adam205348/IMG_2740.jpg)
![](http://i256.photobucket.com/albums/hh171/adam205348/IMG_2737.jpg)
![](http://i256.photobucket.com/albums/hh171/adam205348/IMG_2738.jpg)
![](http://i256.photobucket.com/albums/hh171/adam205348/IMG_2739.jpg)
Fuel and Meth Injection Prices:
A1000 Complete Fuel System w/o Fuel Rails - Original price from HOB was $2120 - $1800 (w/fuel tank you could sell yours for $200-$400)
Magnafuel external fuel system - $1250
I want to sell 1 of the fuel pumps with all the other parts and then the other pump just by itself because selling just the misc parts by them self is not going to be easy unless someone wants just the misc parts. So with that being said. Here are the new prices.
Magnafuel 4303 - $350
HOB A1000 - $550
Misc Parts - $1000
DO NOT ASK WHAT MISC PARTS are as they are all listed in the first post and you will be ignored
The Original Price of the HOB A1000 setup was $2120 but I do not have the fuel rails. So with $200 taken off for the price of rails that would make it $1920 which this comes with a better/more expensive Fuel Labs fuel filter and fuel pressure regulator. So all the parts either will go with the A1000 or the Magnafuel. Would like to sell one of them complete before trying to sell either separate. Let me know what you are interested in.
HOB A1000 - $550
Misc Parts - $1000
