Griffin Radiator -20an line, Pusher Fan, Water Pump Set-up!
Category: Accessories
Price: $725
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): MI
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
-GRI-1-25241-X Griffin Radiator
-Flex-a-lite 420 Low Pro Puller Fans, 2500 CFM
-20an weld on fittings on the radiator inlet and outlet
-20an Stainless Braided hoses
-Factory LS1 water pump with -20an fitting
-160* T-stat with -20an fitting
-Extra -20an straight hose end fittings, black
-Extra -20an hose, few feet, I will have to measure how much exactly
Yes, everything is included, including the modified Water Pump AND T-stat
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Top of radiator has a 90* tube welded on for clearance as you can see. Due to this, and size of the radiator overall, the fan shroud has been trimmed to fit on the radiator, clear the outlets on the radiator and the petcock valve. The -20an fittings were a bear to work with, so they have some scratches on them. Lower hose is red/blue as they were all out of black in the 45's when I needed them. Upper hose uses black fittings. I have 3 I believe Straight -20an hose ends if the buyer needs them.
No issues at all with the set-up, ran great, kept the turbo car cool. Just switching to a different water pump set-up and figure it would be easiest to sell all of this together as it is all made for each other.
$725 shipped OBO for everything!
fans: http://www.summitracing.com/parts/flx-420/overview/
radiator: http://www.summitracing.com/parts/gr...41-x/overview/
hose: http://www.summitracing.com/parts/aer-fca2006/overview/
straight -20an: http://www.summitracing.com/parts/ea...0erl/overview/
weld -20an: http://www.summitracing.com/parts/mez-wf20ma/overview/
45* -20an: http://www.summitracing.com/parts/rus-610140/overview/
![](http://i833.photobucket.com/albums/zz253/Oh-Check/turbo%20stuff/null_zps25629604.jpg)
![](http://i833.photobucket.com/albums/zz253/Oh-Check/turbo%20stuff/null_zps2e5cba17.jpg)
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic36191_1.gif)
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
