SJM line lock ABS delete kit brand new in the box.
Category: Brakes
Price: $175
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): AL
Item Condition: Brand New
LS Engine?: Fits LS Engine
Cost me over 200 new, includes line lock kit, flare tool, ABS delete, and wilwood brake proportioning valve.
Each kit includes:
- Fittings/assemblies necessary for all connections
- Adjustable Wilwood Proportioning Valve with preassembled fittings
- Pre-formed lines
- Proportioning Valve mounting kit
- Complete Instructions including pictorials and schematics.
Copied from their website.
Email me for quickest response. dtrg88@aol.com
Thanks
Russ
Options:
- Re-buildable SJM Solenoid with Electrical kit
* SJM Solenoid
* Micro Toggle Master Switch
* Micro Momentary Control Switch
* Remote LED
* Installation Wire
* Fuse with holder
* Electrical connectors
- Double Flare Tool Kit (modified for metric/standard brake lines)
- Upgrade to shifter switch control for manual transmission vehicles
Benefits:
ABS Kit:
- Deleted ABS controller and bracket
- Removes typically 14-16lbs of weight from the engine bay
- Increased engine bay air flow
- Eliminates front/rear mixed tire diameter dilemmas associated with ABS
- Brake bleeding simplified
- Simplifies turbocharger and supercharger setups
- Cleaner appearance of engine bay
- Allows easier access to engine and enginer components
Line Lock Kit:
- Exclusive two stage switched circuitry
-Visual feedback of circuit activity via remote mount LED indicator
-Installation does not impede with supercharger/turbo kits
- Easy install. Lines, valve and fittings come pre-assembled; brake sealant is not needed for connections
-No modification necessary to existing brake lines
-Solenoid location mounted away from heat sources for years of trouble free operation
-Micro controls can be easily hidden within the interior for stock/stealthy appearance
-Professional installed appearance
-V6 and V8 compatible
-ABS/TCS compatible. Will not interfere with normal ABS/TCS operation when not in use
