WTB stock IAC valve, TPS sensor, & Oil pressure sensor
well i actually have a silverado 2000 model. Mine is a one wire, one prong type on the inside of the sensor pigtail. Im not sure if the oil pressure sensors are interchangable. If they are that would be great. I posted over on this side bc there seems to be more parts floating around.
Brandon,
Are you sure that yours is a "one wire" / "one terminal"
I have a stock low mileage throttle body (dbc) with both sensors and a stock oil pressure switch
the TB w/ sensors is from a 00' -up truck (cable) with 30k miles and the oil pressure switch is from a 99' LS1 with only 500 miles (yes 500)
You can have the TB w/both IAC and TPS sensors and the oil pressure switch for $85 shipped to you
Here are a few pics
Jeff
Here are a few pics
Jeff
