Front sway bar mounts needed
I am looking for the front sway bar Ushaped mounts/bolts so I can install my new spohn sway bar - last owner removed the sway and unfortunately, the mounts are missing as well....Thanks - stevet
Sent you a pm - the other guy sent me the brackets that actually bolt to the frame - which probably are the "mounts" as I asked for. Those are on the car, what I need are the small U shaped pieces of metal that hold the sway bar bushings in place for the sway bar to run through. Each of these are about 4" long and require two bolts each (which I have ) to hold them to the brackets that bolt to the frame. If you have these two pieces I need them...
Thanks - stevet
Thanks - stevet
Thanks - stevet
Thanks - stevet
