What Causes Cat Over Temp (COT)
Old Sep 16, 2003 | 09:53 PM
dug's Avatar
dug
Default What Causes Cat Over Temp (COT)
Does it happen on every car with ory?
Old Sep 17, 2003 | 08:43 AM
HumpinSS's Avatar
Default Re: What Causes Cat Over Temp (COT)
If the computer detects a lean situation it starts dumping fuel to cool the cats down and protect them from overheating. Usually one of the first steps in tuning is to turn it off especially is you dont have cats
Old Sep 17, 2003 | 09:16 AM
jimmyblue's Avatar
Moderator
I've wondered about this, my question is whether
if a car is tuned right, not going lean, will COT
trigger be prevented even at extended periods of
high RPM, high output? What is the O2 voltage
threshold or A/F threshold for COT to stay off?
Old Sep 17, 2003 | 09:53 AM
HumpinSS's Avatar
I am not sure about all the information regarding thresholds and when it kicks in. If the car is tunned appropriately a lean condition shouldnt exist (semi lean maybe)and i am not sure when exactly it starts to kick in but usually anytime COT was discussed it was turned off because it can indiscriminantly add fuel causing the mixture to go rich and kill power.
Usually what happens is the tuner/user wants to lean out the A/F ratio and starts making changes but because COT intervenes it looks as though nothing is changing. Hope this help
Old Sep 17, 2003 | 03:30 PM
gojo's Avatar
You will not be able to tune AFR lean enough for max power with COT not adjusted or disabled. My COT had to be disabled
to get to anywhere from 12.8 to 13.1:1. Don't know what temp. it kicks in.
Old Sep 18, 2003 | 07:53 AM
jimmyblue's Avatar
Moderator
I don't think COT has any direct way of knowing
the cat temps, it just predicts based on some
combo of O2 mV, RPM, time-at-output, and maybe
some engine load params.
Do you know the trigger threshold for AFR (or
O2 mV)? I'd run 12.5:1 up top if it kept me from
falling to 10:1 after 30 seconds of WOT....
Old Oct 14, 2003 | 12:25 AM
Ed Blown Vert's Avatar
Anyway to watch it in EFI or ATAP?
