Knock Sensor
Old Nov 3, 2008 | 07:53 PM
*98TransAm*'s Avatar
Default Knock Sensor
i got a check engine light that states that the knock sensors have low circuit input bank 1 and bank 2. Ive been searching on here awhile about this problem, people have said to replace both sensors and the wiring harness and be sure not to pinch the wires when re-installing the intake. I then came across a thread where someone told me that 98 Ls1's (which is what i have) had major problems with the knock sensors and that when you replace them youll still get the check engine light and the 4 degree retard of timing, he then said just tune out the knock sensors would be the best thing. Is this something i can do with a tech 2 or do i need to find a tuner? thanks
Old Nov 3, 2008 | 08:59 PM
sroach20's Avatar
might want to pull the intake and make sure they arent rusted. if you like spraying your engine down allot to keep it clean, the water may have gotten under the intake to cause the rust.
Old Nov 3, 2008 | 09:16 PM
ive never sprayed my engine down since ive owned it. i guess ill just try replacing them and see what that does. Anybody know anything else about the 98 knock sensors and if i should tune them out or not?
Old Nov 3, 2008 | 09:46 PM
Doc's Avatar
Doc
I bought my 98 off the showroom floor and have never had an issue with the knock sensors like the stories you have read.
They are there for a reason- to pull timing in the pressence of actual knock. This is a good thing. The 98 knock sensor software is a bit agressive I admit but, better safe than sorry.
How long have you owned the car? Is the original LS1 intake still on the car? Many of these cars at this point have been modded and then put back to stock for resale. This is where someone could have pinched a knock sensor wire underneath the intake while re-installing... Or, water could have migrated up underneath the intake and gone by the sensor covers and rusted them out. You'll never know till you pull it.
Last thing on earth would be to turn off their functionality.
What part of Iowa are you from?
I am / was a cornhusker.
Old Nov 3, 2008 | 09:59 PM
I've owned the car for about a year and a half and its been trouble ever since with the tranny and this knock sensor thing. It does have an LS6 intake, it was already on the car when i bought it so maybe a wire was pinched,ill try replacing them and hopefully that will fix the problem.
im actually from bettendorf (the quad cities area on the border of iowa and illinois) Thanks for the help
Old Nov 9, 2008 | 06:35 PM
QuickdomesticRacer's Avatar
Any more updates? My tuner said I needed to replace mine, b/c he heard and saw knock characteristics from his scanner and tuner. But the Knock Sensors did not show anything. But they aren't throwing codes.
I have the car apart and the knock sensors look brand new. Been in the car for atleast 2 1/2+ years since I've owned it.
Any info?
Old Nov 10, 2008 | 08:17 PM
Any info?
nope nothing here, its to damn cold and no garage.
Old Nov 10, 2008 | 11:24 PM
16floz470ml's Avatar
I replaced both knock sensors and the harness when I had my car all apart. Your parts are old and are throwing codes. Unless you pinched the harness I would put in new stuff and never look back.
Old Nov 11, 2008 | 08:06 PM
i asked how much the harness was when i was at the dealer, he said what harness, theres no harness for the knock sensors. I was like wow.
Old Nov 12, 2008 | 07:37 AM
AFASTYZFR1's Avatar
If both are throwing a code, it is most likely the harness.......I just had to buy one from my dealer (think it was around $50)
