OBDII connector port and tuning cable information needed
If someone has a cable that plugs into the GM diagnostic port for OBDII/LS1 series ports I need a dimension. What is the maximum distance that the plug on the cable will use to slide onto the OBDII port? This would be the distance from the leading edge of the cable female housing to the bottom of the pins.
Thanks!
Thanks!
