PREDATOR DIAGNOSTIC TOOLS QUESTION
Old Sep 19, 2003 | 06:04 PM
Jpr5690's Avatar
Default PREDATOR DIAGNOSTIC TOOLS QUESTION
IF MY BUDDY HAS A PREDATOR AND IM USING A HYPERTECH BUT THE CARS ARE BOTH 02 LS1 FBODIES CAN I USE HIS PREDATOR AS A SCAN TOOL ON MY CAR OR WILL IT ONLY LET HIM USE IT ON HIS CAR CAUSE I WANTED TO CHECK OUT MY A\F RATIO AND SEE IN IM GETTING KNOCK WITH MY HPP3 TUNING INSTALLED
THANKS
JOHN
Old Sep 19, 2003 | 06:06 PM
slow's Avatar
Default Re: PREDATOR DIAGNOSTIC TOOLS QUESTION
the predator will work on most OBD-2 GM cars.
I use a locked predator from a 2000 as a scantool for my 98.
The scantool portion is not locked, and will work on as many cars as you want, and will work on most GM OBD-2 cars.
Ryan.
Old Sep 20, 2003 | 01:29 PM
Jpr5690's Avatar
thanks, does it tell if if your runnning lean??? what else will i scan for??
Old Sep 20, 2003 | 01:31 PM
Jpr5690's Avatar
where bouts in o town u located?
Old Sep 20, 2003 | 06:33 PM
WS6FirebirdTA00's Avatar
if u look at fuel trims and o2 is COULD tell u if your lean or not
Old Sep 21, 2003 | 06:40 PM
slow's Avatar
im in longwood, exit 94 on I4
Ryan.
