pink wire on maf,fluctuating 5v or 12v
Old 11-15-2008, 05:25 PM
chetmo's Avatar
Default pink wire on maf,fluctuating 5v or 12v
ok heres my issue;
no maf reading, p0102 code, via hptuners i have flatlined .22 on the maf
i have a good ground, black/white, and the yellow has 5v
is the pink wire supposed to be 12v or fluctuating from 1-5volts. Im getting neither. And also what harness connector(red or blue) does that wire go into.
Im getting in the blue connector a pink wire with no voltage, red i have one pink wire with 12volts. Im trying to see if its a wiring issue, or a PCM issue.
also if its the 12volts, the eng sens fuse is good. What would happened if i ran a jumper 12v wire to it, to see if I received a reading?
Old 11-15-2008, 05:58 PM
the_merv's Avatar
Sounds like you have a break or a short in that power Wire..
Old 11-16-2008, 12:52 PM
chetmo's Avatar
well i ran a jumper wire, and got maf readings, but i unplugged my pcm, now car doesnt want to run, cranks to about 500 rpm and dies.
Old 11-17-2008, 06:42 PM
wait4me's Avatar
pink should have 12v when the key is on
Quick Reply: pink wire on maf,fluctuating 5v or 12v
