What the hell is this code?
Old Nov 16, 2008 | 10:01 AM
michaelg589's Avatar
Angry What the hell is this code?
Just threw two codes today.
The first one came up before : P0410 - Something to do with the air pump. I really dont know what to do about that.
The other, which is confusing, is : P1626 - A website i went to said it could be two different things.
1. Theft Deterrent Fuel Enable Signal Not Received
2. B+ Supply To VCRM A/C Circuit Malfunction
Anyone have any idea what this all means?
Old Nov 16, 2008 | 10:22 AM
2001NBMZ28's Avatar
Secondary air code and theft deterrent - you can look up the descriptions/diagnostics for your year at gearchatter.com
Old Nov 16, 2008 | 10:31 AM
Thank you
Old Dec 11, 2008 | 06:48 PM
Add another code to that list. P0327 - Knock Sensor 1 Circuit. Awesome.
FTL list:
1. P0410
2. P1626
3. P0327
Is anyone else as cool as I am?
Old Dec 11, 2008 | 09:46 PM
LQ9CHEVELLE's Avatar
The PO410 code is usually set by the AIR system. There is a set of one-way AIR valves that keeps exhaust in the manifold from going back up the AIR injection lines, toward the pump. The ECM tests the function of the air system by checking for fluctuations in the 02 sensors when the AIR pump is on (the sensors will pick up on the extra fresh air entering the exhaust stream and fluctuate "lean". When these valves get caked with exhaust crap over time, they get plugged up and dont let as much air through, or sometimes they get stuck shut and dont let any of this air through at all. So.....the pump cycles on, the 02 sensor voltage dosen't change the required minumum amount to signify a "leaning" of the exhaust from the Air injection, and the code sets. You can try cleaning the AIR valves, or just install new ones. I think they are pretty cheap, and the same valves that GM has uses since the 80's im pretty sure. Hope that helps
Old Dec 12, 2008 | 09:30 AM
interesting. thanks for the info. How hard are these vales to get to?
