'01 Z06 w/descreened MAF, just use '02 MAF table?
Just like the title says, my buddy and I are trying to get his and my car tuned in, but we don't have a stock MAF to put back in his car. We're trying to get his dang LTFT's in check (only like +20 at the moment LOL). His is a 2001 but he took the screen out, so we should just be able to use the table from an '02 Z06 that somebody posted a while back, correct?
I know it's not the cause, but we want to make sure that it's not 5 little problems making on big problem.
I know that the '02 and up Z06's had descreened MAF's from the factory, and I looked at the two tables side by side and the difference seems to be about that if you took the screen out of the '01. I just want to make sure.
put a resistor in between the two bottom long posts at the bottom,get a reostat of 1000 - 1500 ohms
so you can adjust the resistance to get the tirms that you want
that mite work for you,
worked awsome on my 99 v6 camaro 5sp when i put a 99 blazer maf on it
hope that helps![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
if you need instructions, or pics to help
just e-mail me corvettezo6_1@yahoo.com
hope that helps
