MAF is consistently maxing out - Options?
I'm consistently maxing the MAF from 80-100% TPS (sometimes even lower). WB is virtually right on compared to commanded AFR (12.85). After a little WOT datalogging today I noticed the MAF actually hit 12220hz in one spot, while the rest of the run was between 11234-11663hz. I've never seen the MAF register that high (12220hz) on my car, but I routinely see it go above 11250hz at WOT. So now I need to consider my options and was looking for some input and suggestions.
Here are some of the options I was thinking about:
1) - Switch to a later year OS
2) - Switch to a 100mm MAF
3) - Switch to Speed Density
Any help and feedback is appreciated.
BTW you cannot flash in a newer 99+ operating system into a 98 pcm. You would need to swap out the pcm, repin the harness, etc.
RedHardSupra - That's for clarification. For some reason I don't have the MAF airflow rate PID selected. I will add it for the next log.
I ran a quick WOT run today and noticed the WB hit 13.2 right at 7040 and 6885 (shift points) rpms, but was fine in the lower rpms. The MAF hz also went above 12K on the first shift point.
