Idle problem!!!
Old Dec 15, 2008 | 07:07 PM
SSPerformance's Avatar
Check the grounds on the back off the head... cheak all your grounds.
Old Dec 15, 2008 | 07:27 PM
linegtdt52's Avatar
no way! It cant be the grounds! 1. I have never touched them. 2. It's not an electrical issue. 3. All components are within range for voltage
Old Dec 15, 2008 | 07:49 PM
Originally Posted by linegtdt52
Sounds and seems like an issue with the circuitry or pcm
Ok i see that you no everything. Have a nice day
Old Dec 16, 2008 | 12:25 AM
kelp's Avatar
dude you are probably spot on but I dont have a scanner. I think my computer did some re-learning when i put the new intake on because I have no leaks what-so-ever and everything else is in working order.
Sure they always reset the LTFTs and it shouldn't make any difference. Intakes don't make much difference in an overall tune. Aside from weird turbulance, it sounds like an air idle problem from your symptoms. You can always differentiate the diagnosis by removing the air filter completely as a test.
Old Dec 16, 2008 | 10:24 AM
edcmat-l1's Avatar
Intakes don't make much difference in a tune? That's a new one on me. At idle the INTAKE might not make a big tune difference, but the bigger throttle body sure will.
And anything off idle, the FAST will make a big difference in the tune.
Old Dec 16, 2008 | 06:32 PM
kelp's Avatar
I am addressing the original poster who said he changed his intake (#21). A TB significantly changes things, but he did not mention that. This is your first post on this thread. I believe we should work together to help out this guy. Please advise him from your experience. Thanks.
Old Dec 16, 2008 | 06:35 PM
linegtdt52's Avatar
Well I am going to do an idle relearn and see if it will help. My battery was colcranking 225 amps so i replaced it now and it cranks faster and idles out quicker but it stil hangs some. it seems to be correcting itself but really doesn't feel right. Maybe the re-learn will elp but I am sure the tune will be inevitable
Old Dec 16, 2008 | 07:31 PM
edcmat-l1's Avatar
I saw that, and based on the fact that he has fast 90/90 in his sig, I figured he replaced both at the same time. If I'm wrong, I apologize.
Old Dec 17, 2008 | 11:32 PM
linegtdt52's Avatar
I think I am going to pull all the plugs and put new wires on the vehicle as well. I believe something is misfiring due to the 8.5mm MSD wires on the car. I think one may be pulled apart but not completely. Atleast I can rest assured knowing I have new plugs and wires. While I am there, I am also going to replace the intake manifold gaskets. I dont believe I used brand new ones and I dont understand how a gasket can just blow but oh well. I have been half assing checking for the problem so I think by doing this I may find the root of the problem or that is atleast what I hope.
Old Dec 17, 2008 | 11:33 PM
linegtdt52's Avatar
Hell I have rusted headers so I may put my pace setters on there just to ward off future problems as well.
Old Dec 18, 2008 | 05:57 AM
edcmat-l1's Avatar
So did you replace the intake AND throttle body at the same time?
Did you put the button head bolts in the valley cover?
Old Dec 18, 2008 | 10:05 PM
  #32
linegtdt52's Avatar
button heads in valley cover and TB and intake at the same time
Old Dec 19, 2008 | 10:44 PM
  #33
linegtdt52's Avatar
problem resolved! replaced battery and 1 spark plug wire.
Old Dec 28, 2008 | 08:39 PM
  #34
linegtdt52's Avatar
UPDATE!!! I now instead of having bank 1 and 2 being lean it's only bank one. It always throws a p0300 code and only under WOT does the P0171 code come up.
Changed fuel filter and checked PSI is at 53. Plug wires are all ok. Changed driverside O2 sensor and no dice. My MAP sensor is reading at 55 but for some reason my fuel stft3 are reading a -33.7% as well as ltft4 reading a negative #. Can someone shed some light on what triggers those fuel trims because it doesnt seem to matter at what TPS%? Thanks guys I am only working with an actron scan tool
Old Dec 29, 2008 | 08:11 AM
  #35
kelp's Avatar
If you have a misfire there is so much gas in the exhaust that it can read a lean AFR.
Old Jan 2, 2009 | 11:26 PM
  #36
linegtdt52's Avatar
problem resolved! fouled injector! not to mention I resecured the map sensor so it fit snug on the fast 90/90 so it may endure a leak-free lifestyle. still have p0300 at idle but I am sure it's from the camshaft.
Old Jan 4, 2009 | 10:21 PM
  #37
linegtdt52's Avatar
P0300 was from camshaft and learned itself out after three ignition cycles! My baby is healthy again!
