Changing Auto to Manual
Old Dec 3, 2008 | 10:34 PM
blackangel327's Avatar
Default Changing Auto to Manual
about to do a custom swap, but its a 5.3, and we are putting a 5 speed behind it. So don't we have to reprogram the computer for the manual trans? the wiring harness is easy because we can just use the 4.8 with a 5 speed, no problems. but can we do it with LS1Edit, Hptunners, or efilive? or do we have to send it off to have it reprogrammed? thanks in advanced.
PS I did do a search so if I missed something I'm sorry.
Old Dec 7, 2008 | 03:42 PM
absolutely no one knows?
Old Dec 7, 2008 | 04:03 PM
sreve's Avatar
any of the ways you mentioned will work
Old Dec 7, 2008 | 08:12 PM
wait4me's Avatar
EFIlive allows you to do segment swaps so you can make your setup exactly how you want as if it was something that came from the manufacturer to begin with.
So all you do is, open your tune, find another tune with the right trans you want with the same OS system and then hit the transfer segment tab and it will move all the hundreds of tables and the behind the scene tables for you and then the car will think it is now an actual manual trans. Pretty simple to do. I dont believe the other software companys do the segment swaps.
Old Dec 7, 2008 | 09:37 PM
so efilive would be the way to go? v1, v2 or tunner? what would I need?
Old Dec 7, 2008 | 09:39 PM
wait4me's Avatar
Call me tommorrow if you get time. I can walk you thru the whole process. Also i can just set up the whole tune for you for free and then you just flash it in.
