Brake related warning lights; help?
He was able to access the computer, or he was not able to do this?
Are the abs fuses good? I would start there. If the abs computer is not receiving power, that will cause alerts and can prevent the tech from accessing the abs controller. If I remember correctly, there is a big fuse and a little fuse for the abs, in the fuseblock under the hood.
If the center high-mounted brake light bulb is not working, it will set a brake warning light.
