Has anyone found a way to make the digtal 7 boxes work?
Old Dec 10, 2008 | 10:12 PM
lt1camaroman93's Avatar
Default Has anyone found a way to make the digtal 7 boxes work?
I have my digital 7 programmable with boost retard from a previous build and want to use it on my ls1 setup. Has anyone found a way to make them work with a multi coil system?
Old Dec 12, 2008 | 11:42 AM
1bad lad's Avatar
there is no reason for us of this box the factory system is very much sufficient
Old Dec 12, 2008 | 01:32 PM
I was unaware that the factory ecu allowed for launch retard and things like that to help the car make a clean launch on a not so well prepped surface. I don't have any experience with the ls1 ecu and boost, so I am heading into this blind.
Old Dec 12, 2008 | 01:45 PM
Fireball's Avatar
can always convert to a distributor setup on your LS1
Old Dec 12, 2008 | 03:41 PM
njc.corp's Avatar
Question
not that i know of-
wegner make a dizzy kit if you want to run a digital 7 box-
i dont think u will need it with all the feautres the pcm can do these days-
what box are u talking about 7530 ,7531 etc etc?
Old Dec 12, 2008 | 05:10 PM
Originally Posted by njc.corp
not that i know of-
7531 is the box I have sitting around. Still new in box, so I figured I should use it. If the stock pcm will do what I need it to do, I will just sell of my digital box to off set some of the cost of the new build.
Old Dec 12, 2008 | 08:59 PM
njc.corp's Avatar
Smile
is the msd-7531 new-
if so let me know if u are selling it i might have a buyer for u
Old Dec 12, 2008 | 09:05 PM
It has been taken out of the box and mounted to a firewall delete panel. Not one wire has been touched or hooked up to anything. Still have all wires, boxes, cd, manual, and serial cable. I will know here soon if I am going to use it or not. I am looking into doing the front mount distributor. My only concern is the car weighs ~2500 and I am looking to make ~1000fwhp, I need a way to get it down the first part of the track.
Old Dec 12, 2008 | 09:59 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Check the FI section. Someone started a thread about breaking the ls1 record, and they are using an MSD 7.
Old Dec 12, 2008 | 10:47 PM
Yep, they are using the distributor style system. I just need to find all what all goes into getting that setup together. Just from looking at a couple pics, it doesn't look cheat. Seems as though you need a timing belt system that runs with no timing cover and the dist is also driven off of that.
Old Dec 13, 2008 | 05:55 PM
njc.corp's Avatar
Smile
check out wegner automotive for the dizzy-
Old Dec 15, 2008 | 12:37 PM
1bad lad's Avatar
sell the msd box and buy hptuners for your set up well worth it
Old Dec 15, 2008 | 02:58 PM
Robin L's Avatar
LS1Tech Sponsor
Here is the deal, MSD makes 2 boxes to run the carb'd engines. One is for the 24 tooth and the other is for the 58 tooth.
MSD also makes a harness kit that allows you to use this box piggyback to the stock ECU and harness. It takes control of your ignition side. The benifit would be the ability to build your own curve. It has an option for a map sensor so your ignition curve could be vacuum or boost sensitive. It looks like you can only use a 2 bar map. That should be good for most people as only the big dogs would see more than 15 pounds on their deal.
The box has a 2 step option as well as a nitrous or step retard option.
The stock ECU's have so many ways to take control of timing. With this setup you take total control of the timing curve.
I have one on the dyno and will use this to get a nitrous retard with the stock ECU. I will let you know how it goes!
Robin
