OL vs. CL with LT's
I have a good tune with the WB of the VE and MAF.
I am currently using only the STFT's, LTFT's off.
With the LT's the nb 02's are not real accurate at idle, after you get going they read pretty well, I have tried the OL/CL tune, but mine stays in OL, is there any good reasons not to just run in OL?
As for the switching tables, they only change the switch point. Changing those tables will not make the 02s react any faster.
2. I will try your first suggestion and I did try the OL idle/CL running using the PE settings and did it correct, but for some reason the car stays in OL and does not switch, actually every now and then it switches in to CL for a little bit then back to OL...does not work correctly.
