ECU problems
Old Dec 13, 2008 | 02:17 PM
Ricky_GD's Avatar
Default ECU problems
Right im having big problems with my LS1 in my GD cobra it car. it has a slight misfire on part throttle at low revs, i have changes plugs leads coils compressions at 190-200 psi only code i get somtimes is p0300, im running out of ideas on as to what this could be. could i have a bad pcm? fuel pressure is at 58psi and have 0280155890 injectors ( is this correct for a 2000 ls1?)
thanks
Old Dec 13, 2008 | 09:32 PM
SS2win's Avatar
pcm rarely goes bad. Have you searched? First two hits on google...
http://www.obd-codes.com/p0300
http://www.random-misfire.com/
Old Dec 15, 2008 | 02:05 PM
Ricky_GD's Avatar
i have searched everywhere still cannot find the problem. is this a problem that can be caused by an ecu being faulty?
Old Dec 15, 2008 | 02:20 PM
1bad lad's Avatar
post up your file
Old Dec 15, 2008 | 02:26 PM
Ricky_GD's Avatar
Originally Posted by 1bad lad
post up your file
do you mean the map thats in the ecu? i havent tried reading this yet, i think its a standard file but as the engine was a cut out there could be anything in there. i may have some equipment at work that can read the file. will try post it up tommorow.
cheers
Old Dec 16, 2008 | 07:50 AM
kirkjames90's Avatar
thanks
mine did exactly as urs did problem was the o2 sensors
i made the mistake of buying some shitty ones that lasted about 4months since i had no cats i replaced the front ones with the backs ones and havent had the problem since
Old Dec 30, 2008 | 08:26 PM
TedsB4Csled's Avatar
I have similar problem. I get PO300 under heavy acceleration. It starts to miss BAD. I have replaced plugs 3X, wires 2X, O2 sensors...etc. It has been going on for months! I may try another set of O2s, but first coil check. I'm glad my other car is reliable.
Old Dec 30, 2008 | 11:25 PM
SS2win's Avatar
Have you checked your Fuel Pressure? I ran into a problem with the factory regulator that caused the pressure to drop over a certain rpm. Fixed with a aftermarket FPR.
Old Dec 30, 2008 | 11:38 PM
1bad lad's Avatar
check your grounds, check your wiring to the crank sensor
Old Dec 31, 2008 | 09:16 AM
Thanks. Will do! Have a Happy New Year!
